Grace Ice & Water Shield on entire low-slope roof
LizzieR | Posted in General Questions on
Hi. I’m Lizzie.
My husband and I are gut renovating a house in New England. Most recently we learned we need to completely replace our roof, including decking, headers, joists due to years of water damage & rot.
We have a low-slope, 2/12 roof. We previously used closed cell spray foam to insulate the underside of the decking. We plan to use asphalt shingles (GAF; their site indicates they can be used on a 2/12…). Our roofing contractor has suggested we use Grace Ice & Water shield on the entirety of our roof under the shingles. A structural engineering/architect friend told us that this is a bad idea since our closed cell spray foam acts as an air and vapor barrier. He said that if the ice & water shield has any leaks (and that eventually it will), moisture that enters won’t have a way out and we risk rotting decking again.
I’m inclined to agree with our friend and I think this would be a no brainer if we had a steeper pitched roof. But I do worry about wind/rain getting under the shingles with such a low pitch. Any guidance and insight is much appreciated! Thank you.
  1. Patrick_OSullivan | | #1
    While their heart is in the right place, the risk mitigated by your roofer's suggestion outweighs (in my opinion) the incremental risk your friend is highlighting.
    Two things:
    (1) Many synthetic roofing underlayments used today are also impermeable (meaning they would inhibit drying, similar to Ice & Water shield.
    (2) Asphalt shingles are also impermeable.
    This article will probably help: https://www.greenbuildingadvisor.com/article/sandwiching-roof-sheathing-two-impermeable-layers
    If it were my 2/12 roof, I would be putting Ice and Water on the whole thing.
    1. LizzieR | | #3
      Thank you for your response and the link!
  2. plumb_bob | | #2
    I agree with Patrick. I put a full layer of I&W under all shingle roofs, regardless of the slope.
    Keep in mind that the shingle installation requirements will be different for low slope application than for a steeper slope.
    1. LizzieR | | #5
      Thank you!
  3. Deleted | | #4
    Deleted
  4. Expert Member
    Michael Maines | | #6
    If you want to increase the assembly's resilience, and make your engineer happy, you could install a vapor-permeable WRB over the existing sheathing, install 2x sleepers and a new layer of sheathing to create a vent space, then install full I+WS and shingles. But it's probably overkill.
    Be aware that installation instructions for shingles on a 2:12 slope are usually different than standard installation instructions, and your roofer may or may not follow those instructions.
    In any case, full I+WS is a good idea for a situation like yours. Even better would be a different type of roofing, such as EPDM, made for low-slope roofs.
    1. LizzieR | | #7
      Appreciate your insight. I'll chat with the roofer re: shingle installation. I downloaded the installation guide from the manufacturer.
      1. Malcolm_Taylor | | #8
        LizzieR,
        Be aware that although you can use shingles at a 2/12 pitch, they are at the very edge of their viability - meaning that they will not have as long a useful life, and are much more prone to leaking than they would otherwise be. That's probably why you are having to do so much work on the roof now. I&WS is the least protection you should add. My own preference would be to use something other than asphalt shingles.
        1. LizzieR | | #9
          Thank you
            Michael Maines | | #10
            Lizzie, I downloaded their installation guide as well, as I was curious what they specifically recommend for a 2:12 pitch. It simply referred to the instructions on the inside of the shingle packaging. Not very helpful when you're in the design stage. Maybe they have other information that I didn't find.
