Getting spray foam into tight spaces
![](https://secure.gravatar.com/avatar/3408ee782c4c9903f780e277062b5f26?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hello,
I finally got to the dry-in stage of my shop. It’s been a long road but I’m fairly pleased with the result. It’s a timber frame enclosed with SIPS. I’m getting ready to foam the gaps around the windows and my door. I have a Dow Great Stuff Gun which I like but I may get a can of the Lock-Tite foam as well for the electrical chases in my panels.
Does anyone have any tips for using the cans versus the gun? I know the cans are kind of a mess if you don’t use the entire can so I want to have a strategy once I start spraying. I have had good luck with the gun but the applicator tip doesn’t seem as narrow as the can so I may try cans for the super tight spots.
I built the structure pretty tight so I guess that’s encouraging.
Thanks.
Hi John...
I believe you can just use a piece of flexible tubing like this:
https://www.homedepot.com/p/UDP-1-4-in-I-D-x-3-8-in-O-D-x-10-ft-Clear-Vinyl-Tubing-T10006005/304185147
also see this video:
https://youtu.be/QbiJA-1Zh3w
hope this helps!
John,
You might want to read "Justin Fink’s Canned Spray Foam Tip" -- along with the article that inspired it, "You Don’t Know Foam."
