Gas direct vent water heater
![](https://secure.gravatar.com/avatar/e1b631af3fce155230bbfd150236dbcf?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
My water heater guy tells me that NG direct vent water heaters only exhaust outside and draw combustion air from inside the home’s envelope. I am trying to avoid any such pressure causing devices and leave air exchange to the HRV. Does anyone know of a 40-50 gallon water heater that draws combustion air from the outside and exhausts outside too? If they don’t exist is this the best reason to go tankless?
thanks, john
John,
If you have a high efficiency modulating boiler I would recommend an indirect hot water tank. An indirect is heated by the boiler and not having a combustion unit itself it can be insulated to a much higher degree.
John,
Plenty of manufacturers make direct-vent sealed combustion gas water heaters:
http://www.amazon.com/Bradford-White-DS150S6FBN-337-Gallon-Natural/dp/B003A69L8I
http://www.rheem.com/product.aspx?id=EE3D5D0D-0FDF-4EF1-B8BD-378FBFA903CC
http://www.statewaterheaters.com/prod/residential/res_gas_pdv.html
Thanks guys. Looks like I need a new water heater guy.
John,
HVAC contractors are usually tied to certain brands of appliances. Sometimes it takes researching finding what appliance specifications you want and finding a contractor that uses these products.
John:
I just got done investigating them myself, and you got two choices: powered direct vent that require 110v. and about $500 more over the basic direct vent. the direct vent uses combustion air from outside via double vent pipe. ( better for tighter homes, but the power direct vent will require combustion air from inside air already heated, so in my case, just a direct vent water heater is more appealing and economical in a couple ways!!
Most high efficiency WH units are capable of using outside sources of combustion air. This is a step that gets skipped for the convenience of the technician. Not a good sign that he/she has your best interests at heart. Find another dealer. Tony Olaivar - HERS Rater, BPI Professional - Lanz Heating and Cooling
