Garrison Style overhang and insulation/rigid foam – Zone 4A
![](https://secure.gravatar.com/avatar/1849900d1ddd2e46fed1bd1ce00c24cc?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
My house has a garrison style overhang of the 2nd floor in 4A. I am planning to do some work where I would need to take down the plywood soffit and the only insulation is a single piece of old fiberglass batt acting as the barrier. I realize cut and cobble is not the optimal solution, but I think it’s the easiest and won’t mess with the details of the siding/soffit. The kicker to this is the overhang has HVAC ducts running down the joists which turn upwards into the 2nd floor bedrooms. So where I would normally want to put a piece of rigid foam directly on the top plate in-between the joists, I think that would let conditioned air condense on the rim joist/subfloor above? So my plan is to cut and cobble rigid foam against the rim joist inside face and then cut and cobble a piece on the bottom side of the joist that would sit on the top plate of the 1st floor wall and run to the rim joist. I think that would then make an air barrier where the conditioned air would stay inside and any moisture could dry inwards towards the house instead of being given a chance to condense with the cold air? Any thoughts or discourse to my plan?
