Garage Wall Assembly
![](https://secure.gravatar.com/avatar/f5cbd14fd5558c24970d554b158291a1?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I’m in the middle of insulating our attached garage. It will not be heated except for a small utility closet.
2×4 walls consist of the following:
1/2 Plywood (interior)
R15 Rockwool
1/2 Plywood
Siga Mavjest 500 SA
Hardie Lap Siding (no rain screen)
I don’t plan on painting the interior plywood. I might seal/coat it with something simple.
Should I be concerned about moisture getting into the walls? Would it be smart to put something like Intello on? Or would it be fine on its own?
I was thinking about filling gaps with putty before sealing. But there will be exposed screws and I want to keep the panels somewhat easily removable for future services/updates (most things come into the house from W garage wall).
The ceiling is drywall. The attic floor will air sealed
