Garage drywall and waterproofing
![](https://secure.gravatar.com/avatar/5730210db14ba879cf3601ecc4361563?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I like to wash out my garage floors so what would be a good drywall/sheetrock design that would keep the bottom 4 feet of the wall from getting saturated with water and damage?
Should I install standard drywall and then coat it with something to make it waterproof? If so, what is a good coating to put on?
Or pay for the Denshield or Greenboard for the bottom 4 feet of the garage wall?
Peter,
The most water-resistant material would probably be cement board (cementitious tile underlayment). For the highest level of water resistance, use a cement-based stucco instead of drywall compound to finish the panels.
Maybe cover with textured fiberglass reinforced plastic (FRP) wall panels.
Is green board with FRP a good way to go?
Green board is not as water resistant as something like DensGlass, and DensGlass really needs a fluid applied water resistant barrier. You might be able to use DensElement (properly installed), but I think Martin has suggested the most cost-effective and bulletproof approach.
