Garage door seal
![](https://secure.gravatar.com/avatar/44b5160e45d62a6f13f874538d2874f9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
We are building a net zero home and trying to find a garage door seal that is tight. Right now the garage door companies we are talking with only use the standard side gripper so concerned a lot of cold air will get in garage. Any recommendations for products that I could recommend to the company we choose.. and/or a garage door company that is known for tight garage doors?
Thanks!
– Karen
You may want to check Garaga weather seal. Their dual lips weather seal makes for a tight seal.
http://www.garaga.com/thermal_break.aspx
http://www.hillsboroughdoors.com/images/Energy_Saving_Poster.pdf
Karen,
I would think an overhead garage door should not be critical for house tightness; the important issue is that the house/garage wall is tight, sealed and well insulated, and if there is a conditioned room above the garage it should be tight, sealed and insulated as well; and the same goes for the garage entry door to the house. I don’t know of anyone that does a door blower test including the garage. Furthermore, all houses with attached garages should have a fan wired to the garage opener, and with a timer, to remove pollution and humidity.
