Garage door R/O framed in directly to slab
![](https://secure.gravatar.com/avatar/2f6ea536a79c81e1dd9f2bcdabcb3d11?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
Hello GBA Community,
I have a garage that was converted into living space Before I bought the property. As I am living in and gutting the house I found the garage door was framed directly on the concrete pad and not on a raised footing. This has caused water intrusion.
I’m thinking possibly a flashing tape or liquid applied membrane possibly from proclima.
There is also a crack in the concrete which I’m planning on using some sort of epoxy seal probably from sika flex.
Thanks for any suggestions
