Garage door detail on FPSF
![](https://secure.gravatar.com/avatar/691106958b5393e245db696f6d754e91?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Doing a FPSF w/ an attached garage(heated) in zone 5a. Does anybody have a good detail for an overhead garage door where it contacts the slab? Have a few ideas in mind, but need something that will last. That is one nasty thermal bridge to contend with….
Ideas to knock around at these two links, and do search here.
https://www.greenbuildingadvisor.com/community/forum/general-questions/22983/retaining-heat-garage-door-part-2a07x
and
https://www.greenbuildingadvisor.com/community/forum/energy-efficiency-and-durability/19854/slab-garage-door-how-insulate-hold-back-pex
good luck. if you come up with anything of genius, let us know. i am still undecided on exactly what to do.
Todd,
I second John's suggestion. After you read through all the comments on the two threads that John linked to, you can post any further questions here.
