furnace efficeincy
![](https://secure.gravatar.com/avatar/196daff15fa80e376d39ce43cd6bb393?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
I have a Carrier gas furnace and am wondering what the efficiency rating is. The model number is 58SS-100-121. The input of the unit is 99,000 BTU/HR output is 119,000 BTU/HR
Please advise,
Norm Hanson
About 120%. Definitely one to hang on to :-).
Guessing from the age, I expect about 80% efficiency. The model number indicates 100,000 BTU/h nominal input, so 99,000 BTU/h actual input sounds right. 119,000 BTU/h must be a mistake, as that should be something more like 79,000 BTU/h, but I'm not sure where that number came from. It's possible that it's actually 119 input and 99 output, in which case it's 83% efficient. That could be the case if it got modified or if the model number is actually 58SS-120-___
If the exact number is not the point, if the vent pipes are made of plastic it is high efficiency condensing that will greater than 90% if the vent pipes are steel it is non condensing less than 83%. I do not recall seeing any models in between.
