Frost-Protected Shallow Foundations
![](https://secure.gravatar.com/avatar/48c23097bb4f97172384bdbcd428ed57?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fk.png&r=g)
I’ve read the ASCE Section 32 that mentions using a FPSF with a crawl space, which I assume includes a strip footing. The question is how to detail this? I’m designing for climate zone 5 in an area that only requires vertical insulation extending 12″ below grade. This is easy when detailing a monolithic footing, but how should a stem wall and strip footing be insulated?
Thanks.
user...016,
See figure #13 on page 25.
https://www.homeinnovation.com/~/media/Files/Reports/Revised-Builders-Guide-to-Frost-Protected-Shallow-Foundations.pdf
Thank you! This is very helpful.
