Framing for Drywall in a Brick Basement
![](https://secure.gravatar.com/avatar/ea4cf9a8f0a3523a908dd0829ade3932?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I have a 1920’s Chicago bungalow with brick foundation walls in basement. I understand the problem with not air sealing and insulating enough will cause problems. Don’t have the space to add 2 inches of rigid insulation and 2×4 wall.
Would a 2×2 wall with no insulation and just drywall work without causing any moisture problems.
thanks Chris
Chris, what is your objective here?
Drywall finished walls . Without having moisture or mold issues. Space constraints make it difficult to bring the wall out further
While you wait for experts to weigh in, read through this Q&A thread and recommended articles: Finishing a Brick-Walled Basement . There's lots to chew on there.
Thanks Kiley.
Your great on FHB podcast.
In a climate with humid summers I think that assembly would be at a risk for mold. Warm humid air would get behind the drywall and condense against the brick, which would be close to ground temperature. You need both insulation and air sealing.
