Foundation/floor strategy for a heated workshop in Zone 6A
![](https://secure.gravatar.com/avatar/3a355a1ac976a2e0b4621eb684f83edb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I am planning a 30’x22′ farm workshop in Eastern Ontario, Canada. I want to end up with a level floor suitable for woodworking machines (table and bandsaws, planer, jointer etc) , Floor will be on grade, location is on a small rise and I will make sure there is good drainage away from building. I will place 2″ of SM insulation under floor. I will most likely frame double stud walls and insulate with 6″ to 7″ of Roxul.
I will heat with a wood stove and will have 4 x 12sq’ windows on the south side. Windows will have heavy curtains for cold nights. I will have one small room inside main room with an electric heater…for storage of paint and frost susceptible products…the main room can go below freezing. Walls will be 10′ high with a prefab truss roof. South facing roof will be approx 30’x 15′ at angle of approx 40 degrees….I plan to place solar panels one day.
A long description I’m afraid, now the questions…..
1. is a concrete floor the best way to go ?
2. which makes most sense in terms of labour, ease of construction, and cost….full block foundation on concrete footing or 10′ sonotube pilings, 10′ apart supporting 6″x6″ posts, framing in between ?
3. I want steel siding outside and plywood walls inside. I am thinking in order (out to in)….steel siding, nailers, typar, sheathing (1/2′ ?), insulation, vapour barrier (yeah, building inspector insists even though this is not a living space), plywood 5/8.
I would greatly appreciate comment, suggestion, or even wild and crazy ideas…thanks,
Mark from Madoc
Mark,
Double stud walls and 6 - 7" of Roxul doesn't add up 2 2x4 walls is 7" cavity. The benefit of double walls is that there can be insulation between the walls. There are mineral wool bats that are 2 1/2" thick and using them between the 2 walls adds r 10 + to the assembly. "Is a concrete slab the best way to go?" Best is very subjective but for what you describe it is certainly very suitable and should be reasonably cost effective. What is your frost depth? The choice of foundation type is strongly dependent on local soil conditions. If your goal is minimum heat loss and your soil allows it, you should consider a " Permenant Wood Foundation" aka PWF. And more than 2" of sub slab insulation, PWFs are heavily pressure treated wood walls that usually sit on gravel that is well drained and extends below frost depth. A 2x8 "pony wall with plywood on both sides and Roxul bats in the spaces between studs will give very good thermal isolation of your slab edge (where most of the heat loss occurs) and serve as the form for pouring the slab. The PWF should cost significantly less than the other alternatives. You need to prevent frost heave of the slab. This means very good drainage under the insulation ideally gravel to below frost depth.
Mark,
Most workshops of the type you describe have a concrete floor. But if there is any reason that you don't like working on concrete, it's always possible to build a building with a wood floor. My guess is that the concrete slab will cost less.
Concerning the foundation details, you should talk to your concrete contractor. If you place the concrete on a layer of crushed stone, I see no reason why you can't install a thickened-edge slab (a monolithic slab). While this type of foundation may be unusual in cold climates, it works just fine for garages and outbuildings, as long as the slab is placed over crushed stone in a well-drained location.
Your reference to "SM insulation" had me scratching my head, so I looked it up. It turns out that SM is a brand name for a type of XPS insulation sold by Dow in Canada. But I guess you know that.
If your local building inspector insists on a vapor barrier for your walls, you might consider installing a smart retarder like MemBrain. It will cost a little more, but it's a better choice in your climate, and will allow more flexible use of your building in the future if the use of the building ever changes. (Remember, the climate is changing.)
Thank you for your comments.
- Frost depth here is assumed to be 48", so all footing is expected to begin at or below that depth.
- Is more than 2" of sub slab insulation really cost effective? This isn't a Passivhaus, just a workshop.
- I like the idea of Roxul surrounding slab perimeter, certainly more environmentally friendly than the
XPS, I do have concerns about the chemicals in pressure treated plywood, is there another
method of encapsulating Roxul on or under the soil?
- I won't be excavating 48" of soil and replacing with gravel, will confine it to removing organic soil,
laying about 12" of coarse gravel, packing to form base for the slab. I will install Big O drainpipe
at 48" depth around the perimeter and cover with same coarse gravel. This will drain out the side
of the rise. Note, must remember to block open end with small stones so local critters don't set
up house in the drain.
I would be quite content to use monolithic slab foundation/floor but; I will have a 30'x14' room on the
side of the shop. It will be a roofed, unheated, uninsulated, gravel floor work/storage area. It's
roof will be a continuation (same slope) of the workshop roof. I want to support the end beam on
4 posts set on concrete pilings. The inspector will not allow the 2 types of foundation...monolithic
slab (shallow depth) and piling (48" depth) in the same building. So I believe I will go with the
concrete pilings all round and pour a slab floor. I am spacing pilings 10' apart, OK with the
inspector as long as I use tube without the bigfoot ( apparently tube plus bigfoot combination was
tested at 7 1/2 foot spacing, so anything greater not approved). I've just discovered Footing Tubes
they seem to make more sense than sonotube. I will see what he makes of that. Sometimes
convincing building officials a frustration....I have several friends in this neck of the woods who
have built strawbale houses....wonderful buildings yet building officials remain skeptical.
Thanks for the MemBrain suggestion, looks promising and you reminded me of the possibility of
a change in use...I hope this building will remain hale and hearty long after I go.
