Formaldehyde-free I-joists
![](https://secure.gravatar.com/avatar/f23865efed7c6d9d824b686dbcda86dd?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
user-945392
| Posted in Green Products and Materials on
Is it possible to get formaldehyde-free I-joists and, if so, who manufactures them? Thanks.
Google http://www.internationalbeams.com/environment/formaldehyde-free/
From AJ's link:
"Formaldehyde concerns are generally limited to urea formaldehyde
adhesives used in the manufacture of wood panel products
intended for interior use where moisture resistance is not required.
International Beams engineered wood products (EWP) contain
no urea formaldehyde as a result of the manufacturing
process."
All of the name brand i-joists are urea free: Boise-Cascade All-Joist, Weyerhauser's ILevel TJI's, and LP SolidStart.
Thanks for the answers. I called Boise-Cascade and they confirmed that they do not use urea-formaldehyde in their I-Joists; their MSDS lists phenol-formaldehyde. Who-formaldehyde? So... a little research later: turns out that there is urea-formaldehyde (used for "interior" applications) and phenol-formaldehyde (used for "exterior" applications). Evidently the phenol-formaldehyde emits significantly less formaldehyde than the urea-formaldehyde. Learn something new every day.
Thanks for pointing me in the right direction!
Will
