Foil-wrapped bubble pack vapor barrier / insulation
![](https://secure.gravatar.com/avatar/161f3b1936a29c79b92ef326a52818c3?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
Any comments on Covertech’s rFOIL brand? Makes great claims when air spaces are created between two layers of foil AND another between the foil and the wall surface – works for my application because
Was reading Martin’s expose on foil barrier sham claims, wondering if some foils are better than others, and if this is a good application for a somewhat limited product.
Gordon,
I have no reason to believe that some brands of foil-faced bubble wrap are better than others.
If you create air spaces and line the air spaces with a radiant barrier, the radiant barrier will help raise the R-value of the air space from about R-1 to R-2 or R-3 -- until the radiant barrier gets dusty. Once it is dusty, the R-value of the air space will drop back down to about R-1.
The improvement in R-value comes from the radiant barrier, not the bubble wrap. If you take this approach, you can save money by purchasing radiant barrier foil rather than foil-faced bubble wrap.
That said, I don't recommend this approach. Real insulation is always cheaper, easier to use, and longer-lasting.
(If any GBA readers want to read my article on the topic, here is the link: Stay Away from Foil-Faced Bubble Wrap.)
