Foil backed OSB in vented roof?
![](https://secure.gravatar.com/avatar/e7486f40976c8f71a7fc60e12d56afa8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I didn’t realize that the building supply company / builder had gone with LP Techshield for my roof sheathing and I am concerned that it could cause moisture issues, I can’t find a moisture transfer spec on the material…only that LP promotes the holes that makes in the foil layer to help with drying.
I am in zone 4a and have vented attics via ridge and soffit venting. Should I be worried about having this material on my house?
Thx!
Bruno, with vented soffits and ridge, having foil on the interior of the roof sheathing is not a problem, and offers the slight benefit of reflecting radiant heat, so your attic won't be quite as hot in summer as it would otherwise be.
Thx!
