foil backed osb
![](https://secure.gravatar.com/avatar/423726d1e1a38aead0929372b96ce55c?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I can buy foil backed osb cheaper right now than regular osb. Pro’s and con’s? It would be used on a hip roof over indoor pool . Asphalt shingles will be very dark. Paint store has a paint called E Barrier to paint under side of exiting osb for same purpose. Pro’s and con’s on it.
It will be a vapor BARRIER due to the foil facer -- no drying at all through it to the side with the foil. Aside from that, I don't really see any downsides. Just make sure to plan your assembly properly with regards to drying.
