Foam insulation on metal siding
![](https://secure.gravatar.com/avatar/3078f0e8b0ecba8edf9d394d35b2d2da?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I am building an all steel barn kit, I plan to use spray foam insulation on the walls and bottom side of the roof . do I need a vapor barrier between the metal siding and roofing or can the foam be sprayed directly to the inside of the metal?
Hi Jeremec,
I assume that you are talking about using closed-cell foam which is not vapor permeable, so you don't need a vapor barrier for vapor control. Something to keep in mind: spraying foam against siding and roofing will basically glue the building together and make remodeling and repairs a challenge. Not sure when you plan to do this work, but we have an article coming later this month on insulating metal buildings that may be helpful.
