Foam insulation gap in 2 foot by 28ft angled ceiling section about 4 inches deep. Can fiberglass batts be used to fill the space?
![](https://secure.gravatar.com/avatar/a42a0f2dd4068d6f98993be924aea6e6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Our home has foam insulation throughout. It took some time but I located a warmer area in an angled ceiling along the entire wall. Now that it is getting cooler this is observed in the same area.
There is a gap where foam is seen under the roof side and t to he raw side of the ceiling.
Could 4 inch fiberglass batts be used to fill the void? My thoughts are if a problem may occur there would be a potential to remove the batts.
Do you have some pics or a drawing? My first thought is that batts might be an issue here, but it really depends what is going on with the venting and what and where there is what I assume you mean is rigid foam.
Thanks Bill,
The foam is open cell spray foam and there is no attic venting.
It’s challenging to get a picture close up as the roof slopes down to the area, but I have a few not-so-clear photos from a few feet away.
The first photo shows the finished ceiling to hopefully give some added .perspective.
Sue
