Foam Board and Spray Foam
![](https://secure.gravatar.com/avatar/176f26a5c81e3d77b3ea3cc8f721b5ca?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Hey,
I’ll be using 2″ EPS against my concrete walls. The stuff I’ll be using us not tongue and groove. I was wondering if I could leave a gap between the boards and Spray Foam in between or should I try to get them as close together and tuck tape them? Also, should I be spray foaming the top and bottom edges as well? Should I leave a gap at the bottom of the floor for spray Foam?
Thanks!
Whenever possible, I'd prefer to butt factory edges tightly against each other, rather than leaving a gap for spray foam. I'm not aware of any tape that sticks well to EPS. You can use foam board adhesive (PL-300 or similar) in a continuous bead along the top of the concrete wall, and additional adhesive to seal the boards to each other. Eventually, you'll end up at a corner where you will need some foam to fill in an irregular gap--concrete walls are rarely perfectly square.
Tim,
As Jon implied, EPS can be difficult to tape. Here's my advice: If your EPS panels have a foil facing, butt the panels tightly together and use tape. If your EPS panels are unfaced, leave enough of a gap for the nozzle of your canned-spray-foam applicator.
