Floor register location in relation to the return register
Hello all,
I have been working really hard to finish up a Florida renovation, but I have ran into another small hurdle. I have floor register (2-1/4×14) that will be installed over hardwood flooring and high wall return register(10×10) in each room. One room in particular, a 13′-9″x 9′-10″ room, the 7in duct is positioned to a have the floor register directly across from the return register.
Will this location cause a problem? I always thought the return should never be too close to the floor register because it could create air flow circulation issues. Any advice or recommendations would be greatly appreciated.
Jimmy
Jimmy,
I wouldn't worry about the situation you describe.
