Flex duct repair?
![](https://secure.gravatar.com/avatar/f5237efe0346d8a8a5e0f7cc253f42b8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
JC72
| Posted in Mechanicals on
Background: 20 yr old duct board plenum + 3 take offs each with a motorized dampers. Over the years technicians have cut into the flex duct to troubleshoot failing/failed dampers. They would close these cuts with either metallic tape, duct tape, or a combination there of. Of course when the tape failed I would follow up with duct tape.
Q: Is it possible to properly repair these short sections (~2ft) of flex duct when I have the plenum replaced in order to reduce the air leakage?
It's best to just replace damaged sections of flex duct. Tape is unlikely to hold up over the long term. You could also try sliding a short section of rigid ducting inside the flex duct and using straps to secure it, similar to how you'd couple two pieces of duct together.
