Flat roof membrane types
Hi All,
I’m looking for advice on the best type of flat roof membrane. I’m currently getting estimates to have a new one put on, with estimates for TPO, EPDM, and fibertite. The roof has ponding issues so I’m also going to have that corrected with tapered foam insulation. I live in zone 6A. Thanks for your insights!
Over the years we tried tar and gravel, Bitumen, EPDM, liquid applied and foam, and to me, TPO is the only way to go. The main things I look for a flat roof material is heat aging, reflectivity and emissivity, UV resistance and puncture resistance. You could also add easy installation, reduction of energy costs and heat-island effect. Look for heat-welded seams, as they provide superior seam strength to taped seams. Look for a product with 30-35 years min. warranties.
Our designs cover CZ2-5, mainly in the South (more rain) and SW (more sun), so you could take it for what is worth. I've never used PVC or FiberTite, so I can't comment on that.
