Flat ceiling creates “attic” in insulated cathedral ceiling. Should be conditioned?
![](https://secure.gravatar.com/avatar/6fddde60bcca18d4a5c2329d30c09428?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hey All,
My home has cathedral ceiling/roof, insulated with fiberboard – no air gap. It has architectural shingle on tar paper, on OSB, on top of old tar/gravel, on top of this ~6 inch fiber panel. At some point a flat ceiling was added in roughly 1/4 of the house in order to route pipes, wires, and an AC system. At that same time they open up vents in the soffits and added a whirlybird.
I have been reading about unvented/conditioned attics and their benefits. My attic already has the exact same insulation as the rest of the house, so spray foaming/additional insulation doesn’t seem necessary? Is it reasonable to seal the soffits and the whirlybird vent, seal THOSE with foam, and then add a small amount of AC to the space? My home is in Central Louisiana.
Please let me know if you would like any additional information, and Thank You!
