Flashing tape on fresh concrete?
How long do we have to wait after pouring concrete before it is dry enough for flashing tape to stick to it properly?
Also, is it a good idea to wait a short period after pouring the foundation walls before starting the subfloor and house framing – to give the concrete a chance to start to dry out before enclosing the crawl space?
Debra,
The higher quality the tape, the more likely you can use it on green concrete. I would say, as long as you are using a high quality tape, you should be able to tape to concrete as long as the concrete doesn't feel damp.
Framers routinely start framing the floor assembly almost immediately -- in some cases, the day after the concrete is placed. Be careful about backfilling, however. You need to have the floor assembly in place, and a certain amount of concrete curing time, before you backfill.
I will have high quality tape. But I also thought that concrete needs to remain moist for a period of time in order to cure properly to full strength and prevent excess cracking.
As for framing the floor assembly right away, I would like to keep the crawl space as dry as possible from the beginning, to reduce potential mold issues (I'm hyper-reactive to mold). Fresh concrete releases a LOT of moisture.
Hoping I can run a dehumidifier under there as soon as the house is dried in, connected to the temporary electric. But a dehumidifier might dry out the concrete too quickly, if it hasn't had a chance to complete some initial curing first.
Debra,
By the time the framers have completed their work, and the window installers, and the roofers -- in other words, the time it takes to get your house dried in -- your concrete will have been curing (hopefully in a moist environment) for a month or two. That's long enough. If you have a roof, you can plug in a dehumidifier at that point if you want.
