Flashing Tape for Tar Paper
![](https://secure.gravatar.com/avatar/d2b802068f374b777585935e398059db?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
What works best with a tar paper WRB for flashing windows, etc? I like 3m 8067 and have used it before to tape to tar paper – but I’m not sure if this works long term. I can’t find anything from 3m, Grace, Typar, that specifically says “ok with tar paper”.
Or, is tar paper better detailed with window flashing extending 4-6″ from the window and the tar paper simply lapped over it?
I’m replacing a wall on my insulated garage. Planned assembly is 2×6 framing, 7/16 ply, WRB, 3/4″ furring, vertical hemlock shiplap. Still on the fence on using tar paper or Tyvek for the WRB. Tar paper seems easier to work with.
I'm not sure tar paper wins out to housewrap in workability. Housewrap is less likely to tear, it comes in wider rolls and compatible tapes. I does win out however (IMO) against most others in vapor control and drying characteristics being that it has variable permeability.
Matt Risinger did a video describing fluid-applied flashing, namely Prosoco R Guard, used to seal tar paper that seemed to work well. I've heard others claim butyl flashings work.
