Flash And Batt (Climate Zone 2)
GoBuildItRight | Posted in Energy Efficiency and Durability on
I’m in the middle of remodeling my house and would like to air/bug seal the exterior fiberboard sheathing from the interior. In order to do this, I’m considering the Flash and Batt insulation technique. {Flash (1/2″-1″Closed Cell Foam) and Batt (mineral wool)}.  I know there’s serious concern with this building technique in the northern climate zones due to condensation but was curious of anyone’s thoughts or personal experiences with Flash/Batt in Climate Zone 2 and how much Closed Cell Spray foam thickness should be utilized?
The existing exterior wall makeup is:
2″ Brick Facade, 1″ Air Gap, 1/2″ Fiber Board, 2×4 Stud Walls, 1/2″ Gyp
  1. Malcolm_Taylor | | #1
    GoBuildItRight,
    There is no minimum thickness for the foam in climate zones 1, 2, or 3.
    BILL WICHERS | | #2
    It's going to be nealy impossible to get an even layer of closed cell foam applied only 1/2" thick. 1" is probably about the minimum installed thickness that is achievable in practice, and it's not going to be particularly even, even if you have a professional crew do the installation.
    You may want to consider doing a full fill of open cell spray foam here and see if it's about the same, or even less, money than the flash and batt you're considering.
