Finishing basement
I have read a number of articles on GBA re: finishing & insulating basements, but struggling to develop a clear plan. I live in Chicago suburbs (zone 5) and recently had an interior French drain installed. My plan was to install dimple mat against concrete as gap and rigid foam against mat. I would prefer to then use vertical & horizonal 1x3s against foam (before drywall) to save space vs 2×4 stud walls. But concerned about attaching 1x3s to concrete wall and creating additional holes in dimple mat. Grateful for any guidance…
Water will tend to run down the surface of the foundation wall so some holes in the dimple mat aren’t likely to be a problem. If you’re really concerned, use the trick I use to keep water out of outdoor masonry anchors (to prevent spalling in a freeze): squirt some silicone into the hole before you install the fastener. The silicone will help to seal around the penetration and close the hole. You want to use a generous blob of silicone for this.
If I was doing this work myself, I’d drill through the stud, foam, and dimple mat into the wall. I’d inject silicone into the hole, then I’d install a tapcon long enough to reach the recommended depth into the masonry. Note that larger size tapcons are MUCH less likely to strip out, so I’d use minimum 1/4” tapcons here.
