Flash-and-Batt Roof Insulation as Ignition Barrier
![](https://secure.gravatar.com/avatar/17298a5dbe11483e4b32bcf142953084?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Do ordinary fiberglass batts in a flash-and-batt roof qualify as an ignition barrier?
More specifically: Building a new house in WA state, outside Seattle. I have a limited-access unvented attic with a flash-and-batt roof above and a drywall ceiling below. The roof insulation is closed-cell spray foam and 10″ fiberglass batts covering the foam. Batts will likely be fastened (not friction-fit). I think an ignition barrier is required, per 2018 IRC R316.5.3. If the batts qualify as an ignition barrier, the requirement is already met, so obviously that’s my preferred outcome.
I know mineral wool will qualify, and you can use the slightly thinner "Safe'n Sound" version to do it to save a little money (compared to the full-depth batts). Mineral wool is used as a fire break commercially all the time.
I don't know if fiberglass ever qualifies. Fiberglass will be harder to keep in place compared with mineral wool too.
Thanks Bill. My understanding is that Safe 'n Sound has no certified R-value, so we'd still need the fiberglass (or something else) to insulate the roof. I'm hoping that the FG batts can do double duty.
If the ceiling is a closed cavity with no access, the drywall is the ignition/thermal barrier.
Thanks Peter, that would simplify things — unfortunately, our attic is large enough to require maintenance access per R807.1.
