Fearing condensation on my gypsy wagon
![](https://secure.gravatar.com/avatar/93c68c73948f92d6285626ac46647f43?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Whew, it’s taken me 4 years to finally get to the stage my gypsy wagon is in now and that is pretty much an uninsulated shed. So how do I insulate without getting mold in my walls.
2×3 framing
3/8 painted plywood on the outside
I have pine for the interior t/g
I have cedar for the exterior t/g
Im trying to make this easy as Im not a builder and Im trying to do this myself as a young single gal with no much experience.
What about Reflectix on the interior studs and then put up my t/g. Someone gave me wool and jeans insulating that Ive been loosely filling the walls with. The studs aren’t a uniform width in between so premeasured insulation isnt that easy.
I was thinking of a Benjamin Obdyke Hydrogap rain screen on the outside of the plywood and then the t/g cedar.
But where will my dew point be? It would be so much easier not to insulate at all but I want this pretty beetle kill blue pine as an interior on my walls.
My space is 12×8. I have 2 windows, a barrel roof with gaps near the top as it wasnt easy to work on the curve. Theres gaps between the wheelwells and the plywood too. I though spray foam here.
Ive been studying Lstibuerek and I kind of understand but its also melting my head. I just want this to be easy and Im so overwhelmed.
Saunas seem like easy construction. That’s what I was going for with the reflectix under the pine t/g.
Also since its a barrel roof on top of a rectangular box of framing, the entire top part (think half barrel on top of a box), the entire barrel part is not insulated.
on the roof I have pine t/g and then 2 inch rigid foam articulated over the curve with spray foam where 2 butt up against each other, then I have ply over that and ice and water shield. Ill finish the roof with a vinyl overlay or rolled asphalt.
So if I need to I could do rigid foam on the outside. Can I just have nothing inside the walls? This would be too much air flow I guess.
Am I making any sense?
HALP!
Im in the pacific northwest Maritime Climate and could possibly move the wagon down to So Cal in the future.
And the biggest thing is the weight issue on a single axle trailer so I always have to keep that in mind.
