Favorite crawlspace liner
Does anyone have a preferred brand of crawlspace vapor barrier.
Needs to be a light color and 10 mil or thicker. Looking to cover 1100 sqft.
thanks
https://www.stegoindustries.com/products/stego-crawl-wrap
I'm in the same boat and about to order the liner for our crawl. I'm looking at 20mil (based on the PDF from this site). Given that there's a picture of fiberglass batts between the joists on the post remediation pictures on that article, I hope that one of the pros here gives updated suggestions.
Joe, Stego and Viper both have thick, white, durable crawl space liners. Viper has several options, depending on your needs. I have also used Tenoarm which is tough stuff but only 8 mils.
Americover has a lot of options up to 20mil, and reinforced too if you want it. I’d go with their white option if you use their product.
