Exterior ridgid polyiso, ok foil faced?
![](https://secure.gravatar.com/avatar/e7f0c299c8aae0fddde7f951df46b0d6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
Wondering if I can use polyiso foil faces on both sides in the following build:
Drywall->2×6 dense packed wall cellulose or fiberglass–>Georgia-pacific Forcefeild taped/sealed–>3.5″ foil faced polyiso insulation.
Ok to use polyiso faced on both sides here?
Drew,
Can you provide a location for where this would be built? The answer is somewhat climate specific. In any case, that’s a very thick wall. Have you considered the cost/payback on that, as opposed to other energy upgrades in a different spot?
Kyle,
Thanks for the reply. I'm in climate zone 5A. I've been planning this build for quite a while and was going to land on Roxul but decided to take advantage of the high R value of polyiso. It's actually lower cost for me to purchase and ship 3.5" polyiso than it is 3". I could probably get Roxul at a slightly lower cost but the R value would drop significantly.
With 3.5" of exterior continuous polyiso you're pretty safe whereever you are -- that's around R23 worth of exterior rigid foam!
It doesn't really matter if you have one or both sides foil faced if you're concerned about the polyiso being a vapor barrier. The foil facer is the part that acts as a vapor barrier, so as soon as at least one side is faced with foil, the polyiso sheet acts as a vapor barrier due to that foil facer. The second facer is no longer relevant.
Thanks Bill. I figured that since I have to detail exterior foam, I might as well go all-out! :) I appreciate your feedback.
