Exterior Insulation Thickness and Vapor Permeance
![](https://secure.gravatar.com/avatar/b40f3fd14a5c37aa53f2d552d9f75515?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
Is there a good resource online to understand how the thickness of exterior insulation (or any material, for that matter) affects the vapor permeance of an assembly?
I hear things like mineral wool and wood fiberboard touted as more vapor permeable than foam, but it seems like if the insulation is thick enough, it approaches a low enough permeance that the differences are not as significant.
Andyfrog,
As usual Martin explains this far better than I could:
https://www.greenbuildingadvisor.com/article/all-about-vapor-diffusion
thanks!
