Exterior insulation – How to install metal flashing around window
bonai | Posted in General Questions on
Hi there,
Like in the attached picture, I am planning to install custom made metal flashing to accommodate 1 1/2″ of exterior foam around already installed windows.
Does the flashing need to be flushed around the window or should a small gap be left?
I am planning to to caulk the corners. Should I also caulk between the window and the flashing?
Cheers.
  1. Malcolm_Taylor | | #1
    Bonai,
    Are you using flanged windows?
