Exterior foundation wall insulation Zone 4A
![](https://www.greenbuildingadvisor.com/app/uploads/assets/avatars/19611-avatar-1593614988-100x100.png)
rhl_
How much insulation do you want on the exterior of a below grade foundation wall in climate Zone 4A?
Ryan,
A minimum of R-10 of continuous insulation, according to most codes.
R100 would be great!
The IRC calls out R10 minimum.
Pick a number between 10 and 100...
If you have access to a foam reclaimer even 4"- 5" of roofing EPS (usually Type VIII, 1.25 lbs per cubic foot) is substantially cheaper than 2.5" of virgin stock Type II (1.5lbs ) or Type IX (2.0lbs.). While less dense foam takes on more moisture into it's interstitial spaces when in soil contact, even Type-I (1.o lbs) delivers better than R3/inch unless the soil is completely saturate (is building in a swamp that requires sump pumps to be working 365 days /year?)
Thanks guys. I know EPS is preferred. We are having some trouble sourcing EPS, the reclaimer people don’t have stock at the moment. We are doing 3” of XPS. I wanted to do 4” but the contractor is making a stink, so Im living with 3”. It’s better than nothing.
"It’s better than nothing."
It's better than R-1o.
