Exterior foam substitute above thermal envelope on attic wall
Hi,
I’m planning 4″ of exterior rigid foam on my walls with a cellulose insulated attic floor. My WRB is outside my rigid foam. Because design uses a monoslope roof, there’s a large portion of attic wall that’s above the thermal envelope of the house. In this area, are there any good assemblies that I can substitute for the rigid foam? My hope would be to reduce labor and use less foam.
–John
John,
The answer depends in part on your siding choice, and whether or not you intend to install vertical furring strips.
If you are installing 1/2" plywood furring strips over your 4 inches of rigid foam, you could, in theory, install three layers of 2x4s as furring strips on your attic wall. That makes the furring strips co-planar.
To me, this approach is costly, fussy, and not worth the trouble. I would just install 4 inches of rigid foam over everything. If you want to save money, buy recycled (reclaimed) rigid foam.
