Exterior continuous insulation on a tiny home?
![](https://secure.gravatar.com/avatar/35eeedc72808eebd102c77ebae3d21da?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
For a home that’s moved only a few times in its life, is it possible to securely fasten rigid mineral wool as exterior insulation?
I assume you can’t use exterior insulation under a metal roof. Is it dumb to have better insulated walls than the roof? I mean, if the roof is the weak point in the insulation, is it wasted money to throw that exterior insulation on the walls?
