Expansion gaps in roof sheathing
![](https://secure.gravatar.com/avatar/c49c6ea92c0080695834d2404db6368a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Do you need a 1/8th expansion gap in your roof sheathing when you have 16 o.c. Framing? This is on an unvented 1:12 slope roof with metal panels. Closed cell spray foam will go on inside of roof sheathing if that matters.
MHunt11,
The gap is not dependent of the spacing of the framing. All that affects is whether you need mid-span supports (like H-clips) or not. Yes you need to leave an expansion gap of 1/8". Many large sheet goods suppliers, like Weyerhaeuser, size their sheets accordingly.
