Existing Basement Stud Wall – What to Do
![](https://secure.gravatar.com/avatar/64518dd048de4d661706aa6d11065a6a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I have a basement that was finished with wood paneling. I am removing it and replacing with drywall. Upon removing the paneling I found 2×2 studs fastened directly to the block wall with a layer of 4mil poly between the studs and the block. There is zero signs of moisture and the studs are in great shape despite being in place since the 80’s. I know this isn’t the most efficient way to do it but what I’m considering doing is removing the poly vapor barrier and placing 1.5” R-tech rigid foam board in between the studs and caulking the edges. This would leave a .25” air gap between the insulation board and drywall. What I want to know is am I setting my self up for a moisture nightmare understanding that this is not the most efficient way to do things but it would put me in a better situation than my current one (non insulated). I appreciate any and all input!
Why not just leave the poly?
