Existing basement slab vapor barrier questions
![](https://secure.gravatar.com/avatar/bdb5cb691ec733567453079262e8d2de?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I’m buying a house with an existing basement slab. It’s mostly in good shape with a few rough patches. I have no idea how old it is, or whether it was installed with a good vapor barrier. I’ve got two questions:
What’s the best test for a homeowner to see if the slab has a good vapor barrier?
Is there a durable, low height, and preferably inexpensive way to add a vapor barrier to the slab top? I’m not looking to finish the basement. I just want to reduce the moisture. I do want something that’s will robustly handle the current roughness of the slab and any future concrete cracking.
A quick test is to put something impervious over a section of floor, then come back later and see if it's wet. Condensation indicates a lack of vapor barrier. Lack of condensation doesn't indicate anything though.
You can paint the floor with a vapor barrier paint.
