Escape Ladders for ICF walls?
We recently built a 2-story ICF house using 10″ block, so the walls are over 12″ thick.
We can’t seem to find an escape ladder that would fit over the windowsills of an ICF home – does anyone have any experience/leads?
Would like to sort out this piece of safety! Thanks!
The model that Wire Cutter ranks their top pick, the X-It, claims to have no limit on wall thickness.
https://www.nytimes.com/wirecutter/reviews/best-fire-escape-ladder/
Werner has one that installs permenantly in a recessed box under the window, and attaches there, so that should also work, althouth the details of mounting to an ICF wall might be something you'd have to figure out and it's certainly something you'd want to be sure to get right.
https://www.wernerco.com/us/products/specialty-products/fire-escape-ladders/ESCSeries
Some, like the ISOP https://isopllc.com/usa/, have carabiners at the top. You could provide your own mount points for those, permanently anchored in the walls. Although you'd be on your own on how to hide them in an aesthetically neutral way without impeding fast access.
The x-it also relies on carabiners for the no wall thickness limit. The optional hooks clearly have a fixed size, implying some definite limit.
Trevor, I think you might be misunderstanding how their hooks are used. The hooks are too small to embrace the wall + trim for even a regular wall. The hooks go over the interior trim (the "stool") with the pointy end pointing into the wall, not down, and the flat part lays on top of the window sill. the straps then go as far as they need to out from there before turning downward.
They do offer a permanent attachment point option with carabiners, but they say no limit on thickness with either arrangement.
https://www.x-itproducts.com/questions/?v=7516fd43adaa
Yes, I was looking at a picture that turned out to be different brand.
