ERV vs fresh air intake
So my HVAC design is looking like I will do a fancoil on each floor.
I’m seriously considering going with an air-to-water chiller for the outdoor unit and a spacepak aircell on each floor, 4 in total.
These units have a 4″ round fresh air port that you can program a percentage of fresh air.
Ideally, I would have an ERV in return-return with each unit. (more Ideally I’d have space for a shaft wall and an independent ERV system :S ) However, ERV’s are quite large and take a lot of space that I don’t have with the unit and all the duct work. Even the panasonic Spot ERV I don’t think I’ll be able to fit one centrally on each floor.
So the big question is, is there a way to model how much energy/cost an ERV will actually save vs straight ventilation?
Thanks,
Jamie
Jamie,
Here is an analysis of the energy savings associated with HRVs or ERVs: Are HRVs Cost-Effective?
You might consider using Lunos fans for ventilation. For more information on Lunos fans, see Designing a Good Ventilation System. Lunos fans don't take up any room.
