ERV Return-Air Filter
Most ducted air handlers are equipped with an air-filter media in the return air plenum. Does the ERV return air need the same? I am planning to use Panasonic Intelibalance ERV. I know that outdoor air is passed thru a MERV 8~13 filter, and return air will meet the exchange core first before being expelled to outside. I am afraid that without a return air filter, the “energy” exchange core may get clogged much sooner!
Does anyone have any experience with a return air filter for ERV? I am using a dedicated 6″ ~4″ ducts for a trunk and branch system for 75 CFM supply. Any details on duct transition to return air plenum and back to ERV will be super helpful.
Found great answer to a similar question at https://www.greenbuildingadvisor.com/question/air-quality-hrv-erv-filter
Found two compatible products at
https://www.hvacquick.com/products/residential/Air-Filters/Inline-Filter-Boxes/HVACQuick-CFB-Series-MERV-13-Inline-Filter-Boxes
and
https://shop.fantech.net/en-US/filter--boxes/c46876
Our ERV (Renewaire) has a filter on each side. One MERV 13 for incoming fresh air and one MERV 8 to protect the unit.
I use a standard 3 1/4x10 register for the stale air pickup. Into the back of this register I cut a strip of washable filter mesh folded into a U shape to increase surface area.
Need to clean it about twice a year, simply take it outside and shake it out. This does a good job of keeping the return ducting clean plus the filter on the ERV barely needs cleaning.
Would you have a picture of this? Not sure I understand. Thanks
