ERV in Cold Wet Climate
![](https://secure.gravatar.com/avatar/f6c19d27c39efedbde9be4cd28f6e076?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Hi everyone. The climate here in Southeast Alaska is notoriously wet. Our outdoor relative humidity is ~80% year round, and our 1% Cooling and 99% Heating temperatures are 69F and 19F respectively.
What effect would an ERV have on indoor humidity levels in such a wet climate? And would special precautions be needed to prevent condensation? I am particularly concerned about exhausting bathrooms.
I’ve seen lots of discussion on ERV’s in cold & dry climates, but none for cold & wet climates.
Thank you,
Chris
ERV's will outperform HRV's in humid climates all else being equal. Being so cold, there is a possible chance of ice forming on the inlet or inside the core. I think there are plenty of threads about this already. I believe the newer models do a better job of resisting freeze but it could still be a possible problem.
Cold air doesn't hold much moisture, so when you take that 80% RH cold air and warm it up to room temperature it will be very dry.
Winter here tends to be pretty high RH as well, currently 32F and 70% RH outside. My ERV works just fine and if I over-ventilate, it will still reduce the indoor humidity bellow comfortable levels.
