EPS and butyl rubber
![](https://secure.gravatar.com/avatar/5730210db14ba879cf3601ecc4361563?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fp.png&r=g)
I had a question regarding a roof SIP and GRACE Ultra Peel & Stick – Butyl Based Membrane. The SIP has an EPS core and my concern is when a fastener punctures the peel & stick membrane, the rubberized butyl gets into the EPS core. It is a rubberized asphalt type of product. Since petroleum and EPS don’t mix, will this cause a problem?
I read that petroleum based products can eat away at EPS and literally melt it. Will this be a problem with GRACE peel & stick on the SIP roof with an EPS core?
Peter,
Butyl-based peel-and-stick products are entirely different from rubberized-asphalt peel-and-stick projects. They use a butyl adhesive and, as far as I know, do not contain asphalt.
If you have any further questions on compatibility, you should direct your questions to the technical help hotline at Grace: 800-444-6459.
