EPDM mechanical fastening
DarylFitz
Can EPDM Roofing run 10 foot widths and mechanical fasteners just on the edges? Is there an issue with it lifting in the wind?
EPDM roofs are generally adhesively bonded to a substrate. If the substrate is foam or coverboard, it is generally fastened to the roof deck with washer-headed mechanical fasteners. The fastening schedule is based on the type of fasteners and substrate and the local wind conditions. Yes, wind uplift is a real threat to rubber roofs. And no, you can't just fasten it at the edges and expect good performance.
