Energy Monitor Without WiFi
![](https://secure.gravatar.com/avatar/b8fbe6749842fd0237577140cd0d85ca?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hello!
I am looking to track peak electricity usage in a commercial building that doesn’t have WiFi or reliable cell service.
Does anyone have any recommendations for energy monitors that might work for this case? Circuit level tracking would be a bonus, but not essential. And I’m willing and able to use a logger that would need to be removed to download data onto a computer.
Thanks in advance!
Andrew
Hi Andrew,
Does your site have any network or internet available? Also, do you need to monitor 3-phase or just split-phase power?
It's possible a Brultech GreenEye Monitor (GEM) might work for your case (https://www.brultech.com/). The GEM has options for wired data output (RS-232 or ethernet if I remember correctly), and their associated DashBox server might work as local storage that you could periodically connect to a laptop to transfer collected data.
If a lack of wireless connectivity is the only issue, could you position a powerline WiFi access point near the load panel such that more common wifi power monitors would work? (example: https://www.bestbuy.com/site/netgear-powerline-ac1000-wi-fi-access-point-and-adapter-white/)
Caveat: I am no expert. I simply researched a bunch of models earlier this year before buying an Emporia Vue for my home.
Cheers!
-Mark
Thanks! This is really helpful. I hadn't come across the Brultech in my research.
The building doesn't have an internet connection (local cable company did a bait and switch on pricing for running cable to the building before and after construction), and the closest building that does have internet is pretty far away, so a repeater isn't a viable option.
Thanks again!
Andrew
Take a look at LoRaWAN technology. Low power long range low bandwidth low cost. Private onsite network with a few gateways. Or there might be a public network operator in your area.
https://lora-alliance.org/buildings-vertical-market/
If you are comfortable with some firmware hacking it is possible to point an Emproia Vue 2 to a local MQTT server say running on a Raspberry Pi with Home Assistant on it.
I haven't done this to my 2 units yet, but have been thinking about it. I like the idea of my data being local.
https://github.com/emporia-vue-local/esphome
