Enclosing a Porch for Conditioned Space
![](https://secure.gravatar.com/avatar/5afab13f8482d67f4f0bbc24d8916963?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
I would like to make an existing bedroom larger by enclosing an adjacent entrance porch that is 7′ x 9′. The deck of the porch is an 8″ thick concrete slab with a basement below. The joists that would be above this deck need to be 2×6’s.
My concern about doing this is that the deck would have two edges covered only with 1/2″ ply and vertical cedar siding.
Would it be sufficient to use closed cell spray foam in the joist bays to insulate this space?
Removing the deck would be a monstrous task which I would rather avoid. Any thoughts would be appreciated.
