Ecoseal Plus Sprayer Specs
![](https://secure.gravatar.com/avatar/8e2c1240717a0f71fbe9a56b2a5bf3a0?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fn.png&r=g)
What sprayers has anyone used to apply Knauf Ecoseal Plus? Knauf specs out a Graco Ultra Max 795, but I am not finding that in any of the local rental shops. I now it should do 3000 psi max, but what other options/needs are there?
Thanks,
Nomran
Norman, I have not sprayed that product but have a different Graco gun I use to spray paint. I believe the only other concern would be the tip size and spray width. Knauf recommends installer training, which you probably know.
The training is online and pretty simple, so I should be good there.
Armando Corbo on this site has used the product a lot. I hope he responds to this thread.
Given the lack of responses, I thought I would weigh in here even though I have no direct experience spraying Ecoseal. But I did photograph the process for a Fine Homebuilding article I worked on in Houston several years ago. The Ecoseal product is very viscous so I don't think a run of the mill airless sprayer is going to cut it. The gas-powered rig (Titan 6900) on this job was the biggest airless sprayer I've ever seen. If I recall correctly, I was told a similar sized electric sprayer was equivalent to the Graco 1095.
