Due to aesthetics, R-20 (4 1/2 inches of rigid foam) above the roof is my limit
![](https://secure.gravatar.com/avatar/c4e9dda17d4c647e6076764038232616?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
Due to aesthetics, R-20 (4 1/2 inches of rigid foam) above the roof is my limit. Would Roxul plus an airspace in the rafter bays be a good choice for the remainder of the needed R-value?
Jesse, 80% of home is concrete slab with remaining 20% being crawl space I closed in – conditioned basement. In a high water table area with no vapor barrier under slab or crawl. De-humidifier runs constantly.
I plan to include air space in rafter bays under sheathing along with batt insulation for remainder of needed R-value. Is an airspace necessary with R-20 foam above roof sheathing?
Cameron,
It looks like you intended to post this on a different page. In most cases, it makes sense to maintain just one thread for a series of questions, rather than starting a new thread each time.
Here is a link to the original thread:
https://www.greenbuildingadvisor.com/community/forum/green-building-techniques/36210/what-recommended-method-insulating-cathedral-ceiling
It would be a good idea to post all answers back on that page.
